Automata Completion and Regularity Preservation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2017
Thomas Genet
We consider rewriting of a regular language with a left-linear term rewriting system. We show two completeness theorems. The first one shows that, if the set of reachable terms is regular, then the equational tree automata completion can compute it. This was known to be true for some term rewriting system classes preserving regularity, but was still an open question in the general case. The proof is not constructive because it depends on regularity of the set of reachable terms, which is undecidable. The second theorem states that, if there exists a regular over-approximation of the set of reachable terms then completion can compute it (or safely under-approximate it). This theorem also provides an algorithmic way to safely explore regular approximations with completion. This has been implemented and used to verify safety properties, automatically, on first-order and higher-order functional programs. To carry out the proof, we also generalize and improve two results of completion: the Termination and the Upper-Bound theorems.
mainLong.pdf (644.64 Ko) Télécharger le fichier
hal-01501744 , version 1 (04-04-2017)
hal-01501744 , version 2 (22-12-2017)
hal-01501744 , version 3 (09-02-2018)
  • HAL Id : hal-01501744 , version 3
Thomas Genet. Automata Completion and Regularity Preservation. [Research Report] IRISA, Inria Rennes. 2017. ⟨hal-01501744v3⟩
665 Consultations
142 Téléchargements
