Identity documents classification as an image classification problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport Technique) Année : 2017
This paper studies the classification of images of identification documents. This problem is critical in various security context where proposed system must offer high performances. We address this challenge as an image classification problem, which has received a large attention from the scientific community. Several image classification methods are evaluated and we report interesting results allowing a better understanding of the specificity of such data. We are especially interested in deep learning approaches, showing good transfer capabilities and high performances.
id_doc_classif2.pdf (5.99 Mo) Télécharger le fichier
hal-01503541 , version 1 (11-04-2017)
hal-01503541 , version 2 (27-04-2017)
  • HAL Id : hal-01503541 , version 2
Ronan Sicre, Ahmad Montaser Awal, Teddy Furon. Identity documents classification as an image classification problem. [Technical Report] RT-0488, Inria Rennes - Bretagne Atlantique; IRISA; AriadNext. 2017. ⟨hal-01503541v2⟩
618 Consultations
2232 Téléchargements
