New interface
Conference papers
Efficient Diffusion on Region Manifolds: Recovering Small Objects with Compact CNN Representations
Ahmet Iscen 1 Giorgos Tolias 2 Yannis Avrithis 1 Teddy Furon 1 Ondřej Chum 2
1 LinkMedia - Creating and exploiting explicit links between multimedia fragments
Inria Rennes – Bretagne Atlantique , IRISA-D6 - MEDIA ET INTERACTIONS
2 VRG - Visual Recognition Group [Prague]
FEL CTU - Faculty of Electrical Engineering [Prague]
Abstract : Query expansion is a popular method to improve the quality of image retrieval with both conventional and CNN representations. It has been so far limited to global image similarity. This work focuses on diffusion, a mechanism that captures the image manifold in the feature space. The diffusion is carried out on descriptors of overlapping image regions rather than on a global image descriptor like in previous approaches. An efficient off-line stage allows optional reduction in the number of stored regions. In the on-line stage, the proposed handling of unseen queries in the indexing stage removes additional computation to adjust the precomputed data. We perform diffusion through a sparse linear system solver, yielding practical query times well below one second. Experimentally, we observe a significant boost in performance of image retrieval with compact CNN descriptors on standard benchmarks, especially when the query object covers only a small part of the image. Small objects have been a common failure case of CNN-based retrieval.
Document type :
Conference papers
Complete list of metadata
Cited literature [63 references]  Display  Hide  Download
https://hal.inria.fr/hal-01505470
Contributor : Ahmet Iscen Connect in order to contact the contributor
Submitted on : Tuesday, April 11, 2017 - 1:23:14 PM
Last modification on : Friday, August 5, 2022 - 2:54:52 PM
Long-term archiving on: : Wednesday, July 12, 2017 - 1:12:41 PM
File
Iscen_cvpr17.pdf
Identifiers
  • HAL Id : hal-01505470, version 1
Citation
Ahmet Iscen, Giorgos Tolias, Yannis Avrithis, Teddy Furon, Ondřej Chum. Efficient Diffusion on Region Manifolds: Recovering Small Objects with Compact CNN Representations. 2017 IEEE Conference on Computer Vision and Pattern Recognition (CVPR), Jul 2017, Honolulu, United States. ⟨hal-01505470⟩
Share
Metrics
Record views
1491
Files downloads
642
