Index Data Structure for Fast Subset and Superset Queries - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Iztok Savnik
  • Fonction : Auteur
  • PersonId : 1006208
A new data structure set-trie for storing and retrieving sets is proposed. Efficient manipulation of sets is vital in a number of systems including datamining tools, object-relational database systems, and rule-based expert systems. Data structure set-trie provides efficient algorithms for set containment operations. It allows fast access to subsets and supersets of a given parameter set. The performance of operations is analyzed empirically in a series of experiments on real-world and artificial datasets. The analysis shows that sets can be accessed in $\mathcal{O}(c*|set|)$ time where |set| represents the size of parameter set and c is a constant.
978-3-642-40511-2_10_Chapter.pdf (150.64 Ko) Télécharger le fichier
hal-01506780 , version 1 (12-04-2017)
Paternité
  • HAL Id : hal-01506780 , version 1
Iztok Savnik. Index Data Structure for Fast Subset and Superset Queries. 1st Cross-Domain Conference and Workshop on Availability, Reliability, and Security in Information Systems (CD-ARES), Sep 2013, Regensburg, Germany. pp.134-148. ⟨hal-01506780⟩
121 Consultations
2848 Téléchargements
