Cosparse Denoising: The Importance of Being Social - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Document Associé À Des Manifestations Scientifiques Année : 2017
This work investigates the performance of cosparse vs. social cosparse regularizations in addressing the audio denoising problem. Beyond the cosparse (also known as sparse analysis) model, results show that exploiting structures in the time-frequency domain is beneficial to audio signal restoration for high degradation levels.
GAULTIERSpars17_CR.pdf (201.95 Ko) Télécharger le fichier
hal-01510710 , version 1 (19-04-2017)
  • HAL Id : hal-01510710 , version 1
Clément Gaultier, Srđan Kitić, Nancy Bertin, Rémi Gribonval. Cosparse Denoising: The Importance of Being Social. The Signal Processing with Adaptive Sparse Structured Representations (SPARS) workshop, Jun 2017, Lisbon, Portugal. ⟨hal-01510710⟩
Relations
507 Consultations
204 Téléchargements
