Formal Verification of a Floating-Point Expansion Renormalization Algorithm - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Many numerical problems require a higher computing precision than the one offered by standard floating-point formats. A common way of extending the precision is to use floating-point expansions. As the problems may be critical and as the algorithms used have very complex proofs (many sub-cases), a formal guarantee of correctness is a wish that can now be fulfilled, using interactive theorem proving. In this article we give a formal proof in Coq for one of the algorithms used as a basic brick when computing with floating-point expansions, the renormaliza-tion, which is usually applied after each operation. It is a critical step needed to ensure that the resulted expansion has the same property as the input one, and is more " compressed ". The formal proof uncovered several gaps in the pen-and-paper proof and gives the algorithm a very high level of guarantee.
itp17.pdf (404.57 Ko) Télécharger le fichier
hal-01512417 , version 1 (23-04-2017)
  • HAL Id : hal-01512417 , version 1
Sylvie Boldo, Mioara Joldes, Jean-Michel Muller, Valentina Popescu. Formal Verification of a Floating-Point Expansion Renormalization Algorithm. 8th International Conference on Interactive Theorem Proving (ITP'2017), Sep 2017, Brasilia, Brazil. ⟨hal-01512417⟩
798 Consultations
927 Téléchargements
