Scalable-Grain Pipeline Parallelization Method for Multi-core Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Peng Liu
  • Fonction : Auteur
  • PersonId : 1006926
Chunming Huang
  • Fonction : Auteur
  • PersonId : 1006927
Jun Guo
  • Fonction : Auteur
  • PersonId : 1006928
Yang Geng
  • Fonction : Auteur
  • PersonId : 1006929
Weidong Wang
  • Fonction : Auteur
  • PersonId : 1006930
How to parallelize the great amount of legacy sequential programs is the most difficult challenge faced by multi-core designers. The existing parallelization methods at the compile time due to the obscured data dependences in C are not suitable for exploring the parallelism of streaming applications. In this paper, a software pipeline for multi-layer loop method is proposed for streaming applications to exploit the coarse-grained pipeline parallelism hidden in multi-layer loops. The proposed method consists of three major steps: 1) transform the task dependence graph of a streaming application to resolve intricate dependence, 2) schedule tasks to multiprocessor system-on-chip with the objective of minimizing the maximal execution time of all pipeline stages, and 3) adjust the granularity of pipeline stages to balance the workload among all stages. The efficiency of the method is validated by case studies of typical streaming applications on multi-core embedded system.
978-3-642-40820-5_23_Chapter.pdf (422.42 Ko) Télécharger le fichier
hal-01513778 , version 1 (25-04-2017)
Paternité
Peng Liu, Chunming Huang, Jun Guo, Yang Geng, Weidong Wang, et al.. Scalable-Grain Pipeline Parallelization Method for Multi-core Systems. 10th International Conference on Network and Parallel Computing (NPC), Sep 2013, Guiyang, China. pp.269-283, ⟨10.1007/978-3-642-40820-5_23⟩. ⟨hal-01513778⟩
83 Consultations
76 Téléchargements
