A double oracle approach to minmax regret optimization problems with interval data - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue European Journal of Operational Research Année : 2017
Hugo Gilbert
  • Fonction : Auteur correspondant
  • PersonId : 971449
Connectez-vous pour contacter l'auteur
Olivier Spanjaard
In this paper, we provide a generic anytime lower bounding procedure for minmax regret optimization problems. We show that the lower bound obtained is always at least as accurate as the lower bound recently proposed by Chassein and Goerigk [3]. This lower bound can be viewed as the optimal value of a linear programming relaxation of a mixed integer programming formulation of minmax regret optimization, but the contribution of the paper is to compute this lower bound via a double oracle algorithm [10] that we specify. The double oracle algorithm is designed by relying on a game theoretic view of robust optimization, similar to the one developed by Mastin et al. [9], and it can be efficiently implemented for any minmax regret optimization problem whose standard version is " easy ". We describe how to efficiently embed this lower bound in a branch and bound procedure. Finally we apply our approach to the robust shortest path problem. Our numerical results show a significant gain in the computation times compared to previous approaches in the literature.
Gilbert_A_double_oracle.pdf (580.36 Ko) Télécharger le fichier
hal-01525976 , version 1 (22-05-2017)
Hugo Gilbert, Olivier Spanjaard. A double oracle approach to minmax regret optimization problems with interval data. European Journal of Operational Research, 2017, ⟨10.1016/j.ejor.2017.04.058⟩. ⟨hal-01525976⟩
268 Consultations
164 Téléchargements
