Conference papers
Using Emulators to Estimate Uncertainty in Complex Models
Abstract : The Managing Uncertainty in Complex Models project has been developing methods for estimating uncertainty in complex models using emulators. Emulators are statistical descriptions of our beliefs about the models (or simulators). They can also be thought of as interpolators of simulator outputs between previous runs. Because they are quick to run, emulators can be used to carry out calculations that would otherwise require large numbers of simulator runs, for example Monte Carlo uncertainty calculations. Both Gaussian and Bayes Linear emulators will be explained and examples given. One of the outputs of the MUCM project is the MUCM toolkit, an on-line recipe book for emulator based methods. Using the toolkit as our basis we will illustrate the breadth of applications that can be addressed by emulator methodology and detail some of the methodology. We will cover sensitivity and uncertainty analysis and describe in less detail other aspects such as how emulators can also be used to calibrate complex computer simulators and how they can be modified for use with stochastic simulators.
Document type :
Conference papers
Complete list of metadata
Cited literature [21 references]  Display  Hide  Download
https://hal.inria.fr/hal-01518680
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Friday, May 5, 2017 - 10:56:01 AM
Last modification on : Saturday, June 8, 2019 - 2:20:03 PM
Long-term archiving on: : Sunday, August 6, 2017 - 12:37:39 PM
File
978-3-642-32677-6_10_Chapter.p...
Identifiers
Citation
Peter Challenor. Using Emulators to Estimate Uncertainty in Complex Models. 10th Working Conference on Uncertainty Quantification in Scientific Computing (WoCoUQ), Aug 2011, Boulder, CO, United States. pp.151-164, ⟨10.1007/978-3-642-32677-6_10⟩. ⟨hal-01518680⟩
Share
Metrics
Record views
92
Files downloads
130
