Computing the monodromy and pole order filtration on Milnor fiber cohomology of plane curves - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Symbolic Computation Année : 2019
We describe an algorithm computing the monodromy and the pole order filtration on the Milnor fiber cohomology of any reduced projective plane curve C. The relation to the zero set of Bernstein-Sato polynomial of the defining homogeneous polynomial for C is also discussed. When C has some non weighted homogeneous singularities, then we have to assume that a conjecture holds in order to get some of our results. In all the examples computed so far this conjecture holds.
comMFgenFINAL.pdf (351.75 Ko) Télécharger le fichier
hal-01518716 , version 1 (04-07-2018)
Alexandru Dimca, Gabriel Sticlaru. Computing the monodromy and pole order filtration on Milnor fiber cohomology of plane curves. Journal of Symbolic Computation, 2019, 91, pp.98-115. ⟨10.1016/j.jsc.2018.06.015⟩. ⟨hal-01518716⟩
300 Consultations
201 Téléchargements
