Step-by-Step Strategies and Case Studies for Embedded Software Companies to Adapt to the FOSS Ecosystem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Suhyun Kim
  • Fonction : Auteur
  • PersonId : 1007712
Jaehyun Yoo
  • Fonction : Auteur
  • PersonId : 1007713
Due to the continuous expansion of the FOSS ecosystem and the introduction of high-quality FOSS, FOSS is increasingly used in consumer electronics (CE) such as smartphones, televisions, and cameras. As a result, manufacturers of CE products have developed a close relationship with the FOSS ecosystem. For CE product manufacturers, efficient adaptation to the FOSS ecosystem has become an essential component in their business operations. This paper will divide the activities of CE product manufacturers within the FOSS ecosystem into the following four levels: identification, adoption, compliance, and contribution. It will examine the main activities and obstacles that arise in each level. The paper will also present instances where companies have succeeded in overcoming these obstacles.
978-3-642-33442-9_4_Chapter.pdf (626.11 Ko) Télécharger le fichier
hal-01519083 , version 1 (05-05-2017)
Paternité
Suhyun Kim, Jaehyun Yoo, Myunghwa Lee. Step-by-Step Strategies and Case Studies for Embedded Software Companies to Adapt to the FOSS Ecosystem. 8th International Conference on Open Source Systems (OSS), Sep 2012, Hammamet, Tunisia. pp.48-60, ⟨10.1007/978-3-642-33442-9_4⟩. ⟨hal-01519083⟩
85 Consultations
194 Téléchargements
