How to Get an Efficient yet Verified Arbitrary-Precision Integer Library - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The GNU Multi-Precision library is a widely used, safety-critical, library for arbitrary-precision arithmetic. Its source code is written in C and assembly, and includes intricate state-of-the-art algorithms for the sake of high performance. Formally verifying the functional behavior of such highly optimized code, not designed with verification in mind, is challenging. We present a fully verified library designed using the Why3 program verifier. The use of a dedicated memory model makes it possible to have the Why3 code be very similar to the original GMP code. This library is extracted to C and is compatible and performance-competitive with GMP.
main.pdf (312.31 Ko) Télécharger le fichier
hal-01519732 , version 1 (09-05-2017)
hal-01519732 , version 2 (31-08-2017)
Raphaël Rieu-Helft, Claude Marché, Guillaume Melquiond. How to Get an Efficient yet Verified Arbitrary-Precision Integer Library. 9th Working Conference on Verified Software: Theories, Tools, and Experiments, Jul 2017, Heidelberg, Germany. pp.84-101, ⟨10.1007/978-3-319-72308-2_6⟩. ⟨hal-01519732v2⟩
525 Consultations
1992 Téléchargements
