Conference papers
Analysis and Design Strategy of On-Chip Charge Pumps for Micro-power Energy Harvesting Applications
Abstract : Charge balance law based on conservation of charge is stated and employed to analyze on-chip linear, Fibonacci and exponential charge pumps. For micro-power on-chip implementations, both the positive- and the negative-plate parasitic capacitors have to be considered. Voltage conversion ratios and efficiencies can be obtained in closed form for single- and dual-branch linear charge pumps, but not for Fibonacci and exponential charge pumps. Instead, a first iteration approximation analysis for computing voltage conversion ratio is proposed. For the linear charge pump, efficiency optimization is achieved by first computing the optimal number of stages, and then obtaining from the required output voltage the reduction factor that is a function of load current, flying capacitor and switching frequency. Using a 0.35(m CMOS process, 8X linear, Fibonacci and exponential charge pumps are designed and their performances are compared and confirmed by extensive Cadence Spectre simulations. It is concluded that linear charge pumps attain the best efficiency.
Document type :
Conference papers
Complete list of metadata
Cited literature [18 references]  Display  Hide  Download
https://hal.inria.fr/hal-01519762
Contributor : Hal Ifip Connect in order to contact the contributor
Submitted on : Tuesday, May 9, 2017 - 11:39:50 AM
Last modification on : Wednesday, June 23, 2021 - 3:10:01 PM
Long-term archiving on: : Thursday, August 10, 2017 - 12:54:15 PM
File
978-3-642-32770-4_10_Chapter.p...
Identifiers
Citation
Wing-Hung Ki, Yan Lu, Feng Su, Chi-Ying Tsui. Analysis and Design Strategy of On-Chip Charge Pumps for Micro-power Energy Harvesting Applications. 19th International Conference on Very Large Scale Integration (VLSISOC), Oct 2011, Hong Kong, China. pp.158-186, ⟨10.1007/978-3-642-32770-4_10⟩. ⟨hal-01519762⟩
Share
Metrics
Record views
122
Files downloads
633
