MISE 3.0: An Agile Support for Collaborative Situation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Mediation Information System Engineering project is starting its third iteration (MISE 3.0). The main objective of this paper is to introduce that version. MISE 3.0 aims at defining and designing a platform, dedicated to detect, initiate and support any collaboration opportunity among potential partners (obviously based on results inherited from MISE 1.0 and MISE 2.0). This MISE 3.0 platform implements the same model-driven engineering approach than MISE 1.0 and MISE 2.0. This approach is structured according to four layers: (i) gathering of individual and collaborative knowledge, (ii) design of potential collaborative behavior, (iii) deployment of accurate collaborative behavior and (iv) management and adaptation of collaborative behavior. However, this new platform is dedicated to provide improvements such as continuous working, performance measurement, smart monitoring and cloud deployment, which are the scientific backbone of this paper.
978-3-642-32775-9_64_Chapter.pdf (421.47 Ko) Télécharger le fichier
hal-01520442 , version 1 (10-05-2017)
Paternité
Frederick Benaben, Matthieu Lauras, Sébastien Truptil, Jacques Lamothe. MISE 3.0: An Agile Support for Collaborative Situation. 13th Working Confeence on Virtual Enterpries (PROVE), Oct 2012, Bournemouth, United Kingdom. pp.645-654, ⟨10.1007/978-3-642-32775-9_64⟩. ⟨hal-01520442⟩
100 Consultations
81 Téléchargements
