Towards CPS Based Aircraft MRO - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Cyber Physical Systems (CPS) receiving more and more industrial reality. In this paper a concept for the application of CPS for Aircraft maintenance repair and overhaul, sketched with airline partners, will be given. Based on industrial needs and requirements as well as the current state of the art the concept is describing a direct assignment of MRO-tasks to mechanic, tools and spare parts in order improve aircraft availability. The planning will be supported through simulation based generation of contextual MRO-tasks.
978-3-642-32775-9_17_Chapter.pdf (307.83 Ko) Télécharger le fichier
hal-01520462 , version 1 (10-05-2017)
Paternité
Kai Mertins, Thomas Knothe, Pavel Gocev. Towards CPS Based Aircraft MRO. 13th Working Confeence on Virtual Enterpries (PROVE), Oct 2012, Bournemouth, United Kingdom. pp.166-173, ⟨10.1007/978-3-642-32775-9_17⟩. ⟨hal-01520462⟩
223 Consultations
151 Téléchargements
