Trust-Aware Clustering Collaborative Filtering: Identification of Relevant Items - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Cosimo Birtolo
  • Fonction : Auteur
  • PersonId : 1008025
Davide Ronca
  • Fonction : Auteur
  • PersonId : 1008026
Gianluca Aurilio
  • Fonction : Auteur
  • PersonId : 1008027
Identifying a customer profile of interest is a challenging task for sellers. Preferences and profile features can range during the time in accordance with current trends. In this paper we investigate the application of different model-based Collaborative Filtering (CF) techniques and in particular propose a trusted approach to user-based clustering CF. We propose a Trust-aware Clustering Collaborative Filtering and we compare several approaches by means of Epinions, which contains explicit trust statements, and MovieLens dataset, where we have implicitly defined a trust information. Experimental results show an increased value of coverage of the recommendations provided by our approach without affecting recommendation quality. To conclude, we introduce a tool, based on recommender systems, able to assist merchants in delivering special offers or in discovering potential interests of their customers. This tool allows each merchant to identify the products to suggest to the target customer in order to best fit his profile of interests.
978-3-642-33409-2_39_Chapter.pdf (1.2 Mo) Télécharger le fichier
hal-01521407 , version 1 (11-05-2017)
Paternité
Cosimo Birtolo, Davide Ronca, Gianluca Aurilio. Trust-Aware Clustering Collaborative Filtering: Identification of Relevant Items. 8th International Conference on Artificial Intelligence Applications and Innovations (AIAI), Sep 2012, Halkidiki, Greece. pp.374-384, ⟨10.1007/978-3-642-33409-2_39⟩. ⟨hal-01521407⟩
97 Consultations
82 Téléchargements
