A multidimensional brush for scatterplot data analytics - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2014
Brushing is a fundamental interaction for visual analytics. A brush is usually defined as a closed region of the screen used to select data items and to highlight them in the current view and other linked views. Scatterplots are also standard ways to visualize values for two variables of a set of multidimensional data. We propose a technique to brush and interactively cluster multidimensional data navigating through a single of their scatterplot projection.
Poster219_MultidimBrush_vis2014_VF.pdf (464.43 Ko) Télécharger le fichier
hal-01523026 , version 1 (16-05-2017)
Michaël Aupetit, Nicolas Heulot, Jean-Daniel Fekete. A multidimensional brush for scatterplot data analytics. IEEE. Visual Analytics Science and Technology (VAST), 2014 IEEE Conference on, Oct 2014, Paris, France. IEEE, pp.221 - 222, 2014, ⟨10.1109/VAST.2014.7042500⟩. ⟨hal-01523026⟩
118 Consultations
289 Téléchargements
