A Sketch for an Adaptive Optimizer for Smalltalk written in Smalltalk - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2002
Eliot Miranda
  • Fonction : Auteur
  • PersonId : 961911
Paolo Bonzini
  • Fonction : Auteur
Steve Dahl
  • Fonction : Auteur
David Griswold
  • Fonction : Auteur
Urs Hölzle
  • Fonction : Auteur
Ian Piumarta
  • Fonction : Auteur
David Simmons
  • Fonction : Auteur
This is a design sketch for an adaptive optimizer implemented in Smalltalk above a conventional "jitting" virtual machine with "minor" extensions. Adaptive optimization as we are discussing it here was invented by Urs Hölzle and is described in [Hölzle94]. The sketch is far from complete, focussing instead on the interface between the optimizer and the virtual machine, hence outlining a potentially portable architecture where an optimizer written in Smalltalk can be hosted above a range of specific virtual machines. This portability is intended to allow us to collaborate on the project without having to define and implement a common vm, with all the difficulties of migrating current systems to a new VM, allowing us to apply the optimizer within our current systems. Of course, this architecture still requires significant extensions to the execution machinery of extant VMs but these extensions amount to something far from a rewrite.
aosta-sketch.pdf (173.76 Ko) Télécharger le fichier
hal-01525754 , version 1 (22-05-2017)
  • HAL Id : hal-01525754 , version 1
Eliot Miranda, Paolo Bonzini, Steve Dahl, David Griswold, Urs Hölzle, et al.. A Sketch for an Adaptive Optimizer for Smalltalk written in Smalltalk. 2002. ⟨hal-01525754⟩
39 Consultations
60 Téléchargements
