Conference papers
Secure and Trustable Distributed Aggregation based on Kademlia
Abstract : Aggregation of values that need to be kept confidential while guaranteeing the robustness of the process and the correctness of the result is required in an increasing number of applications. We propose an aggregation algorithm, which supports a large spectrum of potential applications including complex voting protocols. It relies on the distributed hash table Kademlia, used in BitTorrent, for pseudonymous communication between randomly predetermined peers to ensure a high degree of confidentiality which does not solely relies on cryptography. The distribution of data and computation limits the potential for data breaches, and reduces the need for institutional trust. Experimental results confirm the complexity of O(n) for n peers allowing for large-scale applications.
Complete list of metadata
https://hal.inria.fr/hal-01529326
Contributor : Robert Riemann Connect in order to contact the contributor
Submitted on : Tuesday, August 8, 2017 - 2:27:44 PM
Last modification on : Thursday, October 4, 2018 - 1:19:35 AM
Identifiers
Citation
Stéphane Grumbach, Robert Riemann. Secure and Trustable Distributed Aggregation based on Kademlia. 32th IFIP International Conference on ICT Systems Security and Privacy Protection (SEC), May 2017, Rome, Italy. pp.171-185, ⟨10.1007/978-3-319-58469-0_12⟩. ⟨hal-01529326v2⟩
Share
Metrics
Record views
329
Files downloads
388
