Service interruption on Monday 11 July from 12:30 to 13:00: all the sites of the CCSD (HAL, EpiSciences, SciencesConf, AureHAL) will be inaccessible (network hardware connection).
1UIUC - Department of Computer Science [UIUC] (University of Illinois at Urbana-Champaign • College of Engineering Department of Computer Science 201 North Goodwin Avenue Urbana, IL 61801-2302 - United States)
Abstract : Very large scale systems of autonomous concurrent objects (Actors) require coordination models to meet two competing goals. On the one hand, the coordination models must allow Actors to dynamically modify protocols in order to adapt to requirement changes over the, likely extensive, lifetime of the system. On the other hand, the coordination models must enforce protocols on potentially uncooperative Actors, while preventing deadlocks caused by malicious or faulty Actors. To meet these competing requirements, we introduce a novel, scoped semantics for Synchronizers [7,6]—a coordination model based on declarative synchronization constraints. The mechanism used to limit the scope of the synchronization constraints is based on capabilities and works without central authority. We show that the mechanism closes an attack vector in the original Synchronizer approach which allowed malicious Actors to intentionally deadlock other Actors.
https://hal.inria.fr/hal-01529588 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Wednesday, May 31, 2017 - 9:59:53 AM Last modification on : Thursday, August 1, 2019 - 2:12:06 PM Long-term archiving on: : Wednesday, September 6, 2017 - 3:03:35 PM
Peter Dinges, Gul Agha. Scoped Synchronization Constraints for Large Scale Actor Systems. 14th International Conference on Coordination Models and Languages (COORDINATION), Jun 2012, Stockholm, Sweden. pp.89-103, ⟨10.1007/978-3-642-30829-1_7⟩. ⟨hal-01529588⟩
