Flow Information Storage Assessment Using IPFIXcol - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Petr Velan
  • Fonction : Auteur
  • PersonId : 1009097
Radek Krejčí
  • Fonction : Auteur
  • PersonId : 1009098
Network monitoring has became a significant part of network management. Each environment and type of network have their specific, different needs. To allow network traffic monitoring in various environments, a necessity of flexible approach thus grows. The current generation of flow collectors provides only a limited flexibility, mainly due to limits of their data storage formats. Moreover, it is quite a challenging task to compare particular storage formats and their suitability for the specific environment and usage. In this paper we present IPFIXcol – a flow collector framework designed for easy data storage formats changing. This way, we plan to evaluate performance and suitability of various data storage formats for specific tasks. Results can be used to build the most appropriate data storage for the specific production environments.
978-3-642-30633-4_21_Chapter.pdf (160.55 Ko) Télécharger le fichier
hal-01529780 , version 1 (31-05-2017)
Paternité
Petr Velan, Radek Krejčí. Flow Information Storage Assessment Using IPFIXcol. 6th International Conference on Autonomous Infrastructure (AIMS), Jun 2012, Luxembourg, Luxembourg. pp.155-158, ⟨10.1007/978-3-642-30633-4_21⟩. ⟨hal-01529780⟩
63 Consultations
229 Téléchargements
