Towards Trustworthy Testbeds thanks to Throughout Testing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
When using testbeds in the context of experimental computer science, the ability to produce trustworthy and reproducible experiments results depends greatly on the trustworthiness of the infrastructure itself. Unfortunately, several factors many issues such as software misconfiguration, hardware heterogeneity, or service failures, can remain undetected and affect the quality of experimental results. This paper presents the design and implementation of an automated testbed testing framework. This framework was deployed in the context of the Grid'5000 project, and uncovered more than one hundred of issues.
reppar17-testing-testbeds.pdf (486.88 Ko) Télécharger le fichier
reppar17-testing-testbeds-slides.pdf (496.05 Ko) Télécharger le fichier
Format : Présentation
hal-01538682 , version 1 (13-06-2017)
  • HAL Id : hal-01538682 , version 1
Lucas Nussbaum. Towards Trustworthy Testbeds thanks to Throughout Testing. REPPAR - 4th International Workshop on Reproducibility in Parallel Computing (with IPDPS'2017), Jun 2017, Orlando, United States. pp.9. ⟨hal-01538682⟩
242 Consultations
238 Téléchargements
