Designing and Building SDN Testbeds for Energy-Aware Traffic Engineering Services - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Photonic Network Communications Année : 2017
As experimenting with energy-aware techniques on large-scale production infrastructure is prohibitive , a large number of proposed traffic-engineering strategies have been evaluated only using discrete-event simulations. The present work discusses (i) challenges towards building testbeds that allow researchers and practitioners to validate and evaluate the performance and quality of energy-aware traffic-engineering strategies , (ii) requirements to fulfill when porting simulations to testbeds, and (iii) two proof-of-concept testbeds. One testbed uses and provides Software-Defined Network (SDN) services created on the Open Network Operating System (ONOS) while the other is a composition of virtual Open vSwitches (OVS) controlled by the Ryu SDN framework. The aim of the testbeds is to validate previously proposed energy-aware traffic engineering strategies in different environments. We detail the platforms and illustrate how they have been used for performance evaluation. Additionally, the paper compares results obtained in the testbeds with evaluations performed using discrete-event simulations and presents challenges faced while implementing energy-aware traffic engineering mechanisms as SDN services in testbed environments.
paper.pdf (1.95 Mo) Télécharger le fichier
hal-01539656 , version 1 (15-06-2017)
Marcos Dias de Assuncao, Radu Carpa, Laurent Lefèvre, Olivier Glück, Piotr Borylo, et al.. Designing and Building SDN Testbeds for Energy-Aware Traffic Engineering Services. Photonic Network Communications, 2017, 34 (3), pp.396--410. ⟨10.1007/s11107-017-0709-9⟩. ⟨hal-01539656⟩
267 Consultations
378 Téléchargements
