OrderBased Labeling Scheme for Dynamic XML Query Processing - Archive ouverte HAL Access content directly
Conference Papers Year : 2012
(1) , (1)
1
Beakal Gizachew Assefa
  • Function : Author
  • PersonId : 1010622
Belgin Ergenç
  • Function : Author
  • PersonId : 1010623
Need for robust and high performance XML database systems increased due to growing XML data produced by today’s applications. Like indexes in relational databases, XML labeling is the key to XML querying. Assigning unique labels to nodes of a dynamic XML tree in which the labels encode all structural relationships between the nodes is a challenging problem. Early labeling schemes designed for static XML document generate short labels; however, their performance degrades in update intensive environments due to the need for relabeling. On the other hand, dynamic labeling schemes achieve dynamicity at the cost of large label size or complexity which results in poor query performance. This paper presents OrderBased labeling scheme which is dynamic, simple and compact yet able to identify structural relationships among nodes. A set of performance tests show promising labeling, querying, update performance and optimum label size.
978-3-642-32498-7_22_Chapter.pdf (399.54 Ko) Télécharger le fichier
Dates and versions
hal-01542468 , version 1 (19-06-2017)
Attribution - CC BY 4.0
Identifiers
Cite
Beakal Gizachew Assefa, Belgin Ergenç. OrderBased Labeling Scheme for Dynamic XML Query Processing. International Cross-Domain Conference and Workshop on Availability, Reliability, and Security (CD-ARES), Aug 2012, Prague, Czech Republic. pp.287-301, ⟨10.1007/978-3-642-32498-7_22⟩. ⟨hal-01542468⟩
60 View
108 Download
Share
