Abstract : Due to the wide variety of attacks and the difficulties of developing an accurate statistical model of host features, the structure of the watermark detector is derived by considering a simplified channel model. In this paper, we present a fragile watermarking based on block-mapping mechanism which can perfectly recover the host image from its tampered version by generating a reference data. By investigating characteristics of watermark detector, we make an effective analysis such as fragility against robustness measure and distinguish its property. In particular, we derive a watermark detector structure with simplified channel model which focuses on the error probability versus watermark-to-noise-ratio curve and describes a design by calculating the performance of technique, where attacks are either absent or as noise addition.
https://hal.inria.fr/hal-01542471 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Monday, June 19, 2017 - 5:01:49 PM Last modification on : Thursday, March 5, 2020 - 4:47:37 PM Long-term archiving on: : Friday, December 15, 2017 - 8:06:23 PM
Munkhbaatar Doyoddorj, Kyung-Hyune Rhee. Design and Analysis of a Fragile Watermarking Scheme Based on Block-Mapping. International Cross-Domain Conference and Workshop on Availability, Reliability, and Security (CD-ARES), Aug 2012, Prague, Czech Republic. pp.654-668, ⟨10.1007/978-3-642-32498-7_49⟩. ⟨hal-01542471⟩
