Investigation of WLAN Access Point Placement for Indoor Positioning - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Wireless indoor positioning has been a popular research topic for years because it provides the basis for a broad domain of location-based applications. Especially the usage of WLAN (Wireless Local Area Network) technology is widespread to build an indoor positioning system due to the reuse of existing and almost ubiquitous WLAN infrastructure worldwide lowering the costs. However, these WLAN systems were not originally designed for positioning services, thus the provided accuracy might be low. The accuracy can be increased by the careful placement of WLAN access points to cover the given area appropriately. In this paper, we propose a method based on simulated annealing to find the optimal number and placement of WLAN access points for indoor positioning and show its investigation using simulations.
978-3-642-32808-4_32_Chapter.pdf (342.24 Ko) Télécharger le fichier
hal-01543150 , version 1 (20-06-2017)
Paternité
Árpád Huszák, Győző Gódor, Károly Farkas. Investigation of WLAN Access Point Placement for Indoor Positioning. 18th European Conference on Information and Communications Technologies (EUNICE), Aug 2012, Budapest, Hungary. pp.350-361, ⟨10.1007/978-3-642-32808-4_32⟩. ⟨hal-01543150⟩
85 Consultations
82 Téléchargements
