The Impact of IPv6 on Penetration Testing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Christiaan Ottow
  • Fonction : Auteur
  • PersonId : 1010705
Frank Van Vliet
  • Fonction : Auteur
  • PersonId : 1010706
Pieter-Tjerk De Boer
  • Fonction : Auteur
  • PersonId : 1004798
Aiko Pras
  • Fonction : Auteur
  • PersonId : 994064
In this paper we discuss the impact the use of IPv6 has on remote penetration testing of servers and web applications. Several modifications to the penetration testing process are proposed to accommodate IPv6. Among these modifications are ways of performing fragmentation attacks, host discovery and brute-force protection. We also propose new checks for IPv6-specific vulnerabilities, such as bypassing firewalls using extension headers and reaching internal hosts through available transition mechanisms.The changes to the penetration testing process proposed in this paper can be used by security companies to make their penetration testing process applicable to IPv6 targets.
978-3-642-32808-4_9_Chapter.pdf (114.47 Ko) Télécharger le fichier
hal-01543169 , version 1 (20-06-2017)
Paternité
Christiaan Ottow, Frank Van Vliet, Pieter-Tjerk De Boer, Aiko Pras. The Impact of IPv6 on Penetration Testing. 18th European Conference on Information and Communications Technologies (EUNICE), Aug 2012, Budapest, Hungary. pp.88-99, ⟨10.1007/978-3-642-32808-4_9⟩. ⟨hal-01543169⟩
106 Consultations
383 Téléchargements
