Sliding Mode Control for Turbulent Flows - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The control of turbulent flows is a growing field with major interest, such as in aeronautical industries. This paper deals with the control of a flow separation. The dynamical model of the flow is identified based on experimental data using a specific identification procedure. A setpoint tracking problem is solved by means of Sliding Mode Control methodology. The theoretical results are supported with numerical simulations.
Automatique
main_SM_v3.pdf (4.74 Mo) Télécharger le fichier
hal-01546423 , version 1 (23-06-2017)
  • HAL Id : hal-01546423 , version 1
Maxime Feingesicht, Andrey Polyakov, Franck Kerhervé, Jean-Pierre Richard. Sliding Mode Control for Turbulent Flows. IFAC 2017 - 20th World Congress of the International Federation of Automatic Control, Jul 2017, Toulouse, France. pp.8. ⟨hal-01546423⟩
257 Consultations
195 Téléchargements
