Abstract : After sensors are deployed, it cannot be recharged in Wireless sensor networks. Therefore, the energy of sensors is limited. In this situation, how to design a routing algorithm is very important. An effective algorithm can reduce energy consumption and prolong network lifetime. In this proposal, we proposed a routing protocol. And it can reduce the energy consumption of nodes and use energy effectively to sense by clustering. Finally, we compare the methods we proposed with the others by simulation.
James J. Park; Albert Zomaya; Sang-Soo Yeo; Sartaj Sahni. 9th International Conference on Network and Parallel Computing (NPC), Sep 2012, Gwangju, South Korea. Springer, Lecture Notes in Computer Science, LNCS-7513, pp.421-428, 2012, Network and Parallel Computing. 〈10.1007/978-3-642-35606-3_50〉
https://hal.inria.fr/hal-01551340
Contributeur : Hal Ifip
Soumis le : vendredi 30 juin 2017 - 10:35:53
Dernière modification le : jeudi 22 février 2018 - 19:58:01
Document(s) archivé(s) le : lundi 22 janvier 2018 - 20:57:36
Ying-Hong Wang, Yu-Wei Lin, Yu-Yu Lin, Hang-Ming Chang. Merging Grid into Clustering-Based Routing Protocol for Wireless Sensor Networks. James J. Park; Albert Zomaya; Sang-Soo Yeo; Sartaj Sahni. 9th International Conference on Network and Parallel Computing (NPC), Sep 2012, Gwangju, South Korea. Springer, Lecture Notes in Computer Science, LNCS-7513, pp.421-428, 2012, Network and Parallel Computing. 〈10.1007/978-3-642-35606-3_50〉. 〈hal-01551340〉
