Different Characteristics of Radio Modules in Wireless Body Sensor Network Systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Woosik Lee
  • Fonction : Auteur
  • PersonId : 1011325
Min Choi
  • Fonction : Auteur
  • PersonId : 1011326
Namgi Kim
  • Fonction : Auteur
  • PersonId : 1011327
Wireless body sensor network systems (WB-SNSs) can use diverse radio modules. However, previous studies did not consider different characteristics of radio modules, which deeply impact the performance of WB-SNSs. In this paper, we analyze the performance of WB-SNSs using the representative radio modules CC2420 and CC1000. In this environment, we collected log data from real sensor devices deployed on the human body. After log data collection, we first show that CC2420 and CC1000 have different radio characteristics from diverse views, such as the received signal strength indication (RSSI) average and deviation, transmission power levels, and body movement. Through the analysis, we also find that an efficient transmission power control (TPC) algorithm should consider these diverse factors due to different radio modules.
978-3-642-35606-3_36_Chapter.pdf (531.27 Ko) Télécharger le fichier
hal-01551379 , version 1 (30-06-2017)
Paternité
Woosik Lee, Min Choi, Namgi Kim. Different Characteristics of Radio Modules in Wireless Body Sensor Network Systems. 9th International Conference on Network and Parallel Computing (NPC), Sep 2012, Gwangju, South Korea. pp.308-314, ⟨10.1007/978-3-642-35606-3_36⟩. ⟨hal-01551379⟩
64 Consultations
343 Téléchargements
