OEIRM: An Open Distributed Processing Based Interoperability Reference Model for e-Science - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
E-Science applications are often interdisciplinary and require resources from different infrastructures; the interoperability between heterogeneous infrastructures is an important requirement for constructing large scale experiments. Analyzing interoperability issues by including both application and infrastructure aspects promotes a global view on interoperability of different layers, and we argue it can converge to an optimal reference model to guide the development of service layers in e-Science infrastructures. This paper proposes an Open Distributed Processing based interoperability reference model for e-Science.
978-3-642-35606-3_52_Chapter.pdf (58.73 Ko) Télécharger le fichier
hal-01551380 , version 1 (30-06-2017)
Paternité
Zhiming Zhao, Paola Grosso, Cees De Laat. OEIRM: An Open Distributed Processing Based Interoperability Reference Model for e-Science. 9th International Conference on Network and Parallel Computing (NPC), Sep 2012, Gwangju, South Korea. pp.437-444, ⟨10.1007/978-3-642-35606-3_52⟩. ⟨hal-01551380⟩
129 Consultations
83 Téléchargements
