Unifying Thread-Level Speculation and Transactional Memory - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
João Barreto
  • Fonction : Auteur
  • PersonId : 1011556
Paulo Ferreira
  • Fonction : Auteur
  • PersonId : 1003252
Ricardo Filipe
  • Fonction : Auteur
  • PersonId : 1011558
Rachid Guerraoui
  • Fonction : Auteur
  • PersonId : 853670
The motivation of this work is to ask whether Transactional Memory (TM) and Thread-Level Speculation (TLS), two prominent concurrency paradigms usually considered separately, can be combined into a hybrid approach that extracts untapped parallelism and speed-up from common programs.We show that the answer is positive by describing an algorithm, called TLSTM, that leverages an existing TM with TLS capabilities. We also show that our approach is able to achieve up to a 48% increase in throughput over the base TM, on read dominated workloads of long transactions in a multi-threaded application, among other results.
978-3-642-35170-9_10_Chapter.pdf (683.57 Ko) Télécharger le fichier
hal-01555545 , version 1 (04-07-2017)
Paternité
João Barreto, Aleksandar Dragojevic, Paulo Ferreira, Ricardo Filipe, Rachid Guerraoui. Unifying Thread-Level Speculation and Transactional Memory. 13th International Middleware Conference (MIDDLEWARE), Dec 2012, Montreal, QC, Canada. pp.187-207, ⟨10.1007/978-3-642-35170-9_10⟩. ⟨hal-01555545⟩
40 Consultations
147 Téléchargements
