Small-Scale Soil Database of Jilin Province, China
Choosing the example of Jilin province, the construction method of small scale soil database is discussed; the materials gather from the second soil survey projects are digitized; Jilin province 1:1000000 small scale soil database are established. Commonly, soil database includes the three parts of the spatial database, the attribute database and the metadata database. In the end of this paper, the application prospect of soil database is forecasted; the shortage of existing research results is discussed. The method would provide reference for the construction of small scale soil database in other provinces and regions.
Informatique [cs]
