ARMHEx: A hardware extension for DIFT on ARM-based SoCs - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Security is a major issue nowadays for the embedded systems community. Untrustworthy authorities may use a wide range of attacks in order to retrieve critical information. This paper introduces ARMHEx, a practical solution targeting DIFT (Dynamic Information Flow Tracking) on ARM-based SoCs (e.g. Xilinx Zynq). Current DIFT implementations suffer from two major drawbacks. First, recovering required information for DIFT is generally based on software instrumentation leading to high time overheads. ARMHEx takes profit of ARM CoreSight debug components and static analysis to drastically reduce instrumentation time overhead (up to 90% compared to existing works). Then, security of the DIFT hardware extension itself is not considered in related works. In this work, we tackle this issue by proposing a solution based on ARM Trustzone.
bare_conf.pdf (653.7 Ko) Télécharger le fichier
hal-01558473 , version 1 (07-07-2017)
Muhammad Abdul Wahab, Pascal Cotret, Mounir Nasr Allah, Guillaume Hiet, Vianney Lapotre, et al.. ARMHEx: A hardware extension for DIFT on ARM-based SoCs. 2017 27th International Conference on Field Programmable Logic and Applications (FPL), Sep 2017, Ghent, Belgium. ⟨10.23919/fpl.2017.8056767⟩. ⟨hal-01558473⟩
784 Consultations
988 Téléchargements
