DEM Simulation and Analysis of Seeds Supply by the Vibrating Seed Box of Magnetic Cylinder Seeder - Archive ouverte HAL Access content directly
Conference Papers Year : 2011
(1) , (1) , (1) , (1)
1
Xiuping Shao
  • Function : Author
  • PersonId : 1012429
Jianping Hu
  • Function : Author
Yingsa Huang
  • Function : Author
Fa Liu
  • Function : Author
Regarding the vibrating seeds box of magnetic cylinder seeder as the research subject and making simulation and analysis for the motion law of seeds which supplied by seed box base on DEM (Discrete Element Method). Researching the mechanism of the seed supply and analyzing the condition of seed supply by the vibration of seed box, when the frequency change from 10Hz to 50Hz and horizontal and vertical amplitude of the seed box are 0.5mm. The results shows that the vibrating frequency has greater influence on the seed supply; seeds can’t be supplied when the vibrating frequency less than10Hz; seed can be supplied best and seeds thickness nearly the cylinder wall is highest when the vibrating frequency equal to 40Hz.
978-3-642-18333-1_47_Chapter.pdf (304.11 Ko) Télécharger le fichier
Dates and versions
hal-01559608 , version 1 (10-07-2017)
Attribution - CC BY 4.0
Identifiers
Cite
Xiuping Shao, Jianping Hu, Yingsa Huang, Fa Liu. DEM Simulation and Analysis of Seeds Supply by the Vibrating Seed Box of Magnetic Cylinder Seeder. 4th Conference on Computer and Computing Technologies in Agriculture (CCTA), Oct 2010, Nanchang, China. pp.401-408, ⟨10.1007/978-3-642-18333-1_47⟩. ⟨hal-01559608⟩
37 View
100 Download
Share
