A Method to Calibrate the Electromagnetic Tracking Instrument When Measuring Branches of Fruit Trees - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
To reduce the effect from instrument error when getting characteristic parameters of branches of fruit trees by the electromagnetic tracking instrument, a calibration method was sounded based on a discussion of the instrument error of electromagnetic tracking instrument. Finally, the method was tested in an experiment. By comparing the data of the experiment and the standard data which was got by slide caliper, we proved that the method is effective in increasing the accuracy of measurement.
978-3-642-18333-1_9_Chapter.pdf (90.29 Ko) Télécharger le fichier
hal-01559625 , version 1 (10-07-2017)
Paternité
Ding-Feng Wu, Jian Wang, Guo-Min Zhou, Li-Bo Liu. A Method to Calibrate the Electromagnetic Tracking Instrument When Measuring Branches of Fruit Trees. 4th Conference on Computer and Computing Technologies in Agriculture (CCTA), Oct 2010, Nanchang, China. pp.62-67, ⟨10.1007/978-3-642-18333-1_9⟩. ⟨hal-01559625⟩
87 Consultations
130 Téléchargements
