Application of GPS on Power System Operation
Applying GPS positioning and navigation technology to power systems, will realize precise navigation of power equipments, improve power system automation of routine works, and enhance working efficiency. In case of emergency, rapid fixing arrangements can be implemented through monitoring and command platform. With advance communication technology, the realtime video can be transferred to the experts all over the world for remote joint consultation.
