1Dalian University of Technology (No.2 Linggong Road, Ganjingzi District, Dalian City, Liaoning Province, P. R. C., 116024 - China)
Abstract : In this paper, we propose an image-driven 3D modeling technique for rapid panel design. Our semi-automatic approach is based on template technique and mesh volume deformation controlled by a special cage. We designed our modeling system to be interactive in 2D, automating the process of shape generation while relying on the user to provide image samples. Once a parametric model template is given, using the contour extracted from images, the new control cage corresponding to mesh models generated. Then the geometry of new panel is automatically recovered from the deformable template model. Our system also allows the user to easily reconstruct other 3D objects in a similar manner, such as realistic-looking plant modeling from images. We show realistic reconstructions of a variety of panels, automobile shapes and demonstrate examples of plant editing.
https://hal.inria.fr/hal-01562795 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Monday, July 17, 2017 - 9:50:43 AM Last modification on : Thursday, March 5, 2020 - 5:42:37 PM Long-term archiving on: : Friday, January 26, 2018 - 11:21:12 PM
