Study on Integration of Measurement and Control System for Combine Harvester - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Jin Chen
  • Fonction : Auteur
Yuelan Zheng
  • Fonction : Auteur
  • PersonId : 1012773
Yaoming Li
  • Fonction : Auteur
  • PersonId : 1012774
Xinhua Wei
  • Fonction : Auteur
  • PersonId : 986503
Using CAN (controller area network) field bus and iCAN protocol, an integrated measuring and controlling system for combine harvester is constructed in this paper. ARM is used as the processor of host computer. Lower computers are several measuring and controlling modules of combine harvester. Host computer communicates with lower computers through CAN bus. Information between measurement and control modules can be shared so that combine harvester’s whole performance can be improved. LCD on host computer shows working state and values of relative parameters of each module in real-time. Experiment shows that the system can work correctly and reliably.
978-3-642-18336-2_74_Chapter.pdf (158.5 Ko) Télécharger le fichier
hal-01562802 , version 1 (17-07-2017)
Paternité
Jin Chen, Yuelan Zheng, Yaoming Li, Xinhua Wei. Study on Integration of Measurement and Control System for Combine Harvester. 4th Conference on Computer and Computing Technologies in Agriculture (CCTA), Oct 2010, Nanchang, China. pp.607-614, ⟨10.1007/978-3-642-18336-2_74⟩. ⟨hal-01562802⟩
56 Consultations
79 Téléchargements
