The Spatial and Temporal Prognosis of Oilseed Yield in Shandong Province - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Based on the data about oilseed yield of 87 country units in Shandong province, the paper performed the Moran’s I computerization to analyze the spatial autocorrelation characteristics of the oilseed yield on country level. Results showed that the spatial pattern of the oilseed yield presented the significant agglomeration characteristics, the Moran’s I coefficient of 14 country units was noted quadrant HH, which displayed the country units with a high oilseed yield (above the average) surrounded by country units with high oilseed yield (above the average), the Moran’s I coefficient of 4 country units was noted quadrant LH, which showed the country units with low value surrounded by country units with high values, the Moran’s I coefficient of 22 country units was noted quadrant LL, which indicated the country units with low oilseed yield surrounded by country units with low oilseed yield, the autocorrelation of the other country units was not evident. The study also carried out to predict the total oilseed yield with ARIMA (2,1,2) model on basis of time series data, in order to explore the trend of the total oilseed yield in Shandong province, the average relative error between observation value and prediction value is 2.12% only using statistical oilseed yield data during 1978-2008, the better reliability. In a word, Moran’s I coefficient and ARIMA (2,1,2) model can fairly clarify the spatial and temporal status of oilseed yield. What’s more, the study is to provide a better understanding of temporal and spatial patterns of oilseed yield in Shandong province.
978-3-642-18354-6_20_Chapter.pdf (643.27 Ko) Télécharger le fichier
hal-01563404 , version 1 (17-07-2017)
Paternité
Yujian Yang, Jianhua Zhu, Shubo Wan, Xiaoyan Zhang. The Spatial and Temporal Prognosis of Oilseed Yield in Shandong Province. 4th Conference on Computer and Computing Technologies in Agriculture (CCTA), Oct 2010, Nanchang, China. pp.146-157, ⟨10.1007/978-3-642-18354-6_20⟩. ⟨hal-01563404⟩
45 Consultations
107 Téléchargements
