Study on the Near Infrared Model Development of Mixed Liquid Samples by the Algorithm of OSC-PLS - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The orthogonal signal correction of Wold algorithm was introduced in this thesis, which was combined with the partial least square algorithm. Calibration model of five components of benzene, methylbenzene, chlorobenzene, benzaldehyde and acetophenone in the mixed liquid samples were developed and validated by the method of independent . The result indicated that the calibration models of the components of benzene, methylbenzene, chlorobenzene and benzaldehyde will be developed well after the 1-dimension OSC filter; while a good calibration model of the component of acetophenone will be acquired after the 2-dimension OSC filter.
978-3-642-18354-6_69_Chapter.pdf (200.76 Ko) Télécharger le fichier
hal-01563475 , version 1 (17-07-2017)
Paternité
Dong Wang, Zhihong Ma, Shengfeng Ye, Shungeng Min. Study on the Near Infrared Model Development of Mixed Liquid Samples by the Algorithm of OSC-PLS. 4th Conference on Computer and Computing Technologies in Agriculture (CCTA), Oct 2010, Nanchang, China. pp.592-597, ⟨10.1007/978-3-642-18354-6_69⟩. ⟨hal-01563475⟩
29 Consultations
100 Téléchargements
