Turning Function Calls Into Animations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Animated transitions are an integral part of modern interaction frameworks. With the increasing number of animation scenarios, they have grown in range of animatable features. Yet not all transitions can be smoothed: programming systems limit the flexibility of frameworks for animating new things, and force them to expose low-level details to programmers. We present an ongoing work to provide system-wide animation of objects, by introducing a delay operator. This operator turns setter function calls into animations. It offers a coherent way to express animations across frameworks, and facilitates the animation of new properties.
eics17-hal.pdf (762.88 Ko) Télécharger le fichier
hal-01564116 , version 1 (18-07-2017)
Thibault Raffaillac, Stéphane Huot, Stéphane Ducasse. Turning Function Calls Into Animations. The 9th ACM SIGCHI Symposium on Engineering Interactive Computing Systems, Jun 2017, Lisbon, Portugal. pp.81-86, ⟨10.1145/3102113.3102134⟩. ⟨hal-01564116⟩
342 Consultations
294 Téléchargements
