A New Modular Marx Derived Multilevel Converter - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
José Fernando Silva
  • Fonction : Auteur
  • PersonId : 976808
Sónia F. Pinto
  • Fonction : Auteur
  • PersonId : 988863
Luis. M. Redondo
  • Fonction : Auteur
  • PersonId : 988868
A new Modular Marx Multilevel Converter, M3C, is presented. The M3C topology was developed based on the Marx Generator concept and can contribute to technological innovation for sustainability by enabling wind energy off-shore modular multilevel power switching converters with an arbitrary number of levels. This paper solves both the DC capacitor voltage balancing problem and modularity problems of multilevel converters, using a modified cell of a solid-state Marx modulator, previously developed by authors for high voltage pulsed power applications. The paper details the structure and operation of the M3C modules, and their assembling to obtain multilevel converters. Sliding mode control is applied to a M3C leg and the vector leading to automatic capacitor voltage equalization is chosen. Simulation results are presented to show the effectiveness of the proposed M3C topology.
978-3-642-19170-1_63_Chapter.pdf (168.51 Ko) Télécharger le fichier
hal-01566555 , version 1 (21-07-2017)
Paternité
Luis Encarnação, José Fernando Silva, Sónia F. Pinto, Luis. M. Redondo. A New Modular Marx Derived Multilevel Converter. 2nd Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Feb 2011, Costa de Caparica, Portugal. pp.573-580, ⟨10.1007/978-3-642-19170-1_63⟩. ⟨hal-01566555⟩
54 Consultations
88 Téléchargements
