Abstract : One potential advantage of the application of superconducting materials in electrical machines is the possibility to build lighter and compact devices by removing iron. These machines find applications, e.g., in systems where cryogenics is already available, or in naturally cryogenic environments. The design of motors with high temperature superconductors (HTS) presents issues unconsidered in classical machines, besides considerations on cryogenics, such as HTS brittleness or mechanical restrictions. Moreover, HTS’ electromagnetic properties also degrade due to flux density components, which arise if there is no iron to guide magnetic flux. Several aspects must thus be considered in the design stage, as applications may turn less attractive or even unfeasible. In this paper these issues are detailed, and a numerical methodology for the design of an all superconducting (without iron or conventional conductors) linear synchronous motor is presented.
https://hal.inria.fr/hal-01566586 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Friday, July 21, 2017 - 11:25:42 AM Last modification on : Tuesday, June 29, 2021 - 12:20:08 PM
João Pina, Mário Neves, Alfredo Álvarez, Amadeu Rodrigues. Numerical Design Methodology for an All Superconducting Linear Synchronous Motor. 2nd Doctoral Conference on Computing, Electrical and Industrial Systems (DoCEIS), Feb 2011, Costa de Caparica, Portugal. pp.553-562, ⟨10.1007/978-3-642-19170-1_61⟩. ⟨hal-01566586⟩
