Organizational Power and Information Security Rule Compliance - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Ella Kolkowska
  • Fonction : Auteur
  • PersonId : 989274
Gurpreet Dhillon
  • Fonction : Auteur
  • PersonId : 989216
This paper analyzes power relationships and the resulting failure in complying with information security rules. We argue that inability to understand the intricate power relationships in the design and implementation of information security rules leads to a lack of compliance with the intended policy. We conduct the argument through an empirical, qualitative case study set in a Swedish Social Services organization. Our findings suggest a relationship between dimensions of power and information security rules and the impact there might be on compliance behavior. This also helps to improve configuration of security rules through proactive information security management.
978-3-642-21424-0_15_Chapter.pdf (74.09 Ko) Télécharger le fichier
hal-01567592 , version 1 (24-07-2017)
Paternité
Ella Kolkowska, Gurpreet Dhillon. Organizational Power and Information Security Rule Compliance. 26th International Information Security Conference (SEC), Jun 2011, Lucerne, Switzerland. pp.185-196, ⟨10.1007/978-3-642-21424-0_15⟩. ⟨hal-01567592⟩
57 Consultations
383 Téléchargements
