Methods for Studying the Information Systems Future - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Paul Gray
  • Fonction : Auteur
  • PersonId : 1013484
Anat Hovav
  • Fonction : Auteur
  • PersonId : 1013485
Information Systems studies involve the present and the future. Although data can be obtained on the present, the future can only be estimated. In Information Systems, a rapidly changing intellectual and technological field, simply extrapolating the present to the future is likely to be wrong. This paper presents and explains three proven research methods for studying the IS future and describes the role of Futures Research methods as a tool for academic research.
978-3-642-21364-9_21_Chapter.pdf (193.62 Ko) Télécharger le fichier
hal-01567986 , version 1 (24-07-2017)
Paternité
Paul Gray, Anat Hovav. Methods for Studying the Information Systems Future. 1st Working Conference Researching the Future (Future-IS), Jun 2011, Turku, Finland. pp.299-316, ⟨10.1007/978-3-642-21364-9_21⟩. ⟨hal-01567986⟩
73 Consultations
108 Téléchargements
