Abstract : This paper deals with an efficiency of current municipal expenditure on environmental protection and suggests a methodology for assessing this efficiency. A proposal of methodological procedure for evaluating efficiency of municipal environmental protection expenditure uses multi-criteria evaluation, where a dominant criterion of performance is modified method of Cost-effectiveness analysis. It was implemented in open source software. The efficiency in the methodology is intended in terms of 3E methodology – Economy, Efficiency and Effectiveness, together with the methodology of sustainable development – social, environmental and economic part of sustainable development. This procedure is applied to a set of environmental protection expenditure data that come from the representative sample of municipalities in areas of waste management which were used in a project of the Ministry of Environment of the Czech Republic SP/4i1/54/08 “Analysis of municipal budgets efficiency in relation to the environmental protection”.
https://hal.inria.fr/hal-01569189 Contributor : Hal IfipConnect in order to contact the contributor Submitted on : Wednesday, July 26, 2017 - 2:05:44 PM Last modification on : Wednesday, November 18, 2020 - 6:32:03 PM
Jana Soukopová, Michal Struk. Methodology for the Efficiency Evaluation of the Municipal Environmental Protection Expenditure. 9th International Symposium on Environmental Software Systems (ISESS), Jun 2011, Brno, Czech Republic. pp.327-340, ⟨10.1007/978-3-642-22285-6_36⟩. ⟨hal-01569189⟩
