Searching Massive Data Streams Using Multipattern Regular Expressions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This paper describes the design and implementation of lightgrep, a multipattern regular expression search tool that efficiently searches massive data streams. lightgrep addresses several shortcomings of existing digital forensic tools by taking advantage of recent developments in automata theory. The tool directly simulates a nondeterministic finite automaton, and incorporates a number of practical optimizations related to searching with large pattern sets.
978-3-642-24212-0_4_Chapter.pdf (312.77 Ko) Télécharger le fichier
hal-01569547 , version 1 (27-07-2017)
Paternité
Jon Stewart, Joel Uckelman. Searching Massive Data Streams Using Multipattern Regular Expressions. 7th Digital Forensics (DF), Jan 2011, Orlando, FL, United States. pp.49-63, ⟨10.1007/978-3-642-24212-0_4⟩. ⟨hal-01569547⟩
63 Consultations
309 Téléchargements
