Mining rare sequential patterns with ASP - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This article presents an approach of meaningful rare sequential pattern mining based on the declarative programming paradigm of Answer Set Programming (ASP). The setting of rare sequential pattern mining is introduced. Our ASP approach provides an easy manner to encode expert constraints on expected patterns to cope with the huge amount of meaningless rare patterns. Encodings are presented and quantitatively compared to a procedural baseline. An application on care pathways analysis illustrates the interest of expert constraints encoding.
ilp_samet_2017.pdf (374.2 Ko) Télécharger le fichier
hal-01569582 , version 1 (27-07-2017)
  • HAL Id : hal-01569582 , version 1
Ahmed Samet, Thomas Guyet, Benjamin Negrevergne. Mining rare sequential patterns with ASP. ILP 2017 - 27th International Conference on Inductive Logic Programming, Sep 2017, Orléans, France. ⟨hal-01569582⟩
781 Consultations
476 Téléchargements
