Journal articles
Optimization and control of bio-conversion of polymeric substrate in the chemostat
Jacques-Alexandre Sepulchre 1 Francis Mairet 2, 3 Jean-Luc Gouzé 2, 3
2 BIOCORE - Biological control of artificial ecosystems
LOV - Laboratoire d'océanographie de Villefranche, CRISAM - Inria Sophia Antipolis - Méditerranée , INRA - Institut National de la Recherche Agronomique
Abstract : We design a simple model of the growth of polymer-decomposing bacteria in a continuous stirred tank reactor. The dilution rate is controled to optimize the output of monomers. This model is studied in order to find the optimum at the stationary state. However, the optimal stationary state is not robust against perturbations, leading to washout in the bioreactor. We design a control that makes the closed system globally stable around the optimal equilibrium. Then, a more complex model for polymers and oligomers of any lengths is studied. It is shown that the same technics also lead to a globally stable optimal point for the controlled system.
Complete list of metadata
Cited literature [25 references]  Display  Hide  Download
https://hal.inria.fr/hal-01569696
Contributor : Jean-Luc Gouzé Connect in order to contact the contributor
Submitted on : Thursday, July 27, 2017 - 12:07:53 PM
Last modification on : Thursday, August 4, 2022 - 5:05:42 PM
File
article-20170530.pdf
Identifiers
Citation
Jacques-Alexandre Sepulchre, Francis Mairet, Jean-Luc Gouzé. Optimization and control of bio-conversion of polymeric substrate in the chemostat. AIChE Journal, Wiley, 2017, 63 (11), pp.4738-4747. ⟨10.1002/aic.15853⟩. ⟨hal-01569696⟩
Share
Metrics
Record views
217
Files downloads
132
